P0106 and P1336
Old Nov 26, 2014 | 03:54 PM
99RamAirLS1's Avatar
Default P0106 and P1336
Got new motor put together and put back into my 94 Z28, Stock LT1 with LS computer and coilpack conversion, LT4 Heads, Intake and Comp Cam. The car doesnt seem to idle well and has hicuups when driving for sure.
Codes came up P0106 and P1336, Car is only showing 5% vacuum at idle of about 1k RPMS.
I am reading about Crankshaft relearn? I havent had a chance to have car tuned on just trying to get advice from anyone else who may have had these codes?
Thanks!
Old Nov 26, 2014 | 08:03 PM
joecar's Avatar
MAP sensor problem... do you have the right MAP sensor.
Old Nov 26, 2014 | 08:39 PM
Im not sure, its the stock Map Sensor I believe? How would I know does it need to change to LS style since running LS computer?
Old Nov 27, 2014 | 09:38 AM
ChevyOwner's Avatar
Did you modify the wiring or buy a harness? Why two threads? (https://ls1tech.com/forums/lt1-lt4-m...106-p1336.html)
Old Nov 29, 2014 | 10:29 PM
Modified
Old Nov 30, 2014 | 07:44 AM
ChevyOwner's Avatar
You may want to verify that did not cross wires for the MAP sensor then.
