How do i avoid downshift 3-2 on dyno ?
Old May 26, 2004 | 05:27 PM
Rune's Avatar
Default How do i avoid downshift 3-2 on dyno ?
I tried with LS1Edit to reprogram 3-2 downshift mph to a much lower setting, was 82 mph, set 50 mph, but it still down shifted even if speed was above 50 mph when going to WOT ???
Any other tables that needs to be adressed ?
TIA
Old May 29, 2004 | 02:28 PM
BluHawk141's Avatar
You need to go to the normal shift table, the hot shift table, and the table on the main page. Change the speed on the 2-1 shift and the 3-2 shift to 20 miles an hour. Make sure you change all 3 tables. Also make sure the car is in drive and not over drive on the dyno and you'll have no problems.
Old May 31, 2004 | 12:16 PM
Rune's Avatar
Thank you, will try that...
