which standalone on boosted LS
http://www.efisource.com/shop/ms3-lsx-plug-and-play/
or Microsquirt. That comes with the standalone harness.
http://www.efisource.com/shop/ls1-24...-play-harness/
Both of those have the new design VR input, that allows the LSx engine to be easily setup on a Megasquirt EFI. No more adjustment of the VR pots.
If you like Megasquirt tech and are comfortable with it, that is the way to go.
Next setup to look at, would be the Holley, HP or Dominator, setups.
Make sure you are clear on all the Harnesses required to use each Holley system. They are generally bought seperately, and add up quickly.
I heard that the pricing of Holley products are going up next year, so keep that in mind also.
Wideband o2 sensor, up to 5 bar Map, and built in Boost Control
4l60/4l80 transmission control with the Dominator unit
and Drive by wire with the Dominator unit
