What is Lambda questions inside.
Old Dec 22, 2014 | 09:15 PM
RonSSNova's Avatar
1/ pid6010
I've used it on both my cars. 0896 PCM's for both.
Ron
Old Dec 23, 2014 | 03:59 AM
1970camaroRS's Avatar
1/ pid6010
Ron
I couldn't get that to work on my 0411 PCM.
Old Dec 24, 2014 | 01:59 AM
RonSSNova's Avatar
Hmmm. Odd.
The 0411 is supposed to be nearly identical.
What didn't work? Did you put EQ Ratio in the table display?
Or is EQ Ratio not a choice?
I should add commanded AFR hi res in mine and write the PID you did and make sure it matches.
Ron
Old Dec 24, 2014 | 03:35 PM
PID 6010 comes back to me as unsupported parameter. I didn't want to fuss with it much so I just did the easy math of commanded afr/stoich = lambda. I suppose I could spend more time to make it work, but since my setup is working fine as is I haven't put any more effort into it.
Old Dec 27, 2014 | 12:39 PM
JoshBoody's Avatar
Stating only lambda matters is true for reading afr... BUT AFR matters greatly in the tune, as this is how PCM calcs fuel per air mass. This maybe why some get confused on this topic.
If e10 is 14.42 I suspect it's not e10... if my math is right. Pumps is "up to" e10 I think.
