having hell with histograms
Old Dec 19, 2014 | 09:00 PM
codyvette's Avatar
Default having hell with histograms
I must first admit I am more car than computer. That said, I am having hell setting up histograms for specific readings. I am trying to set up to log for MAF corrections on a 2000 Camaro. Even when I insert a file from the tuning class I took into the unused histogram slot it tells me the perameter is not supported. Any help dumbing this process down is appreciated.
Old Dec 21, 2014 | 02:24 AM
1970camaroRS's Avatar
HP tuners? Try running the scanner when connected to your car? There are a few that will read as unsupported unless running an active scan. Also, make sure you have Air Fuel Ratio Commanded Hi Res loaded. And Mass Air Flow (SAE) loaded.
