air fuel ratio?????
Old May 27, 2004 | 07:47 PM
Bill's 02 Z-28 SS's Avatar
Default air fuel ratio?????
Hi folks
What is the best AFR to use for LS1 with LS6 cam, ported LS6 heads (11.2:1), LTH, and 36 injectors. I keep reading numbers from 12.6 to 13.5. What should I try, I know once I get a number, it will changes depending on how well it does.
Thanks
Bill
Old May 27, 2004 | 07:52 PM
Turo's Avatar
13.1 seems to be a good all-around number. each car is different though, you have to get a dyno tune to find your optimal ratio
Old May 27, 2004 | 09:13 PM
ataylors's Avatar
just start with the richer (12.6:1) log A LOT!! and work it from there.
Old May 28, 2004 | 07:23 AM
Thanks - will try it.
Bill
