Help Identifying What PCM/Harness I need
Old Jan 27, 2015 | 09:28 PM
TXjeepTJ's Avatar
Default Help Identifying What PCM/Harness I need
I just picked up a 6.0L LQ4. It "came" with a wiring harness, but was cut up beyond recognition - did not even have PCM connectors (which would have helped me out a lot). I was able to find a part number sticker on it though: 15929552
I was told it came out of a 2007 Chevy 2500 box truck.
I pulled the Crank Sensor - and it looks like it is a 24x reluctor ring. I just checked the part number on the crank sensor and it is saying it is a sensor for a 24x reluctor. It is also DBW/electric throttle body.
Anyone know if this is the older style harness/pcm or the newer (e38)?
Old Jan 27, 2015 | 10:27 PM
LSX Power Tuning's Avatar
If its a 24X its not an E38.
Old Jan 28, 2015 | 08:05 AM
TXjeepTJ's Avatar
Awesome..
And since it is a 24x - could I toss the DBW TB and get a cable driven one - then just buy a cable driven harness and be good to go? (and get a PCM that runs a 6.0 w/ cable TB)
Old Jan 28, 2015 | 08:26 AM
Correct you can switch to DBC if you get the right harness, pcm and a cable TB. You need a 896 or 411 pcm.
