Silverado Ls1 E-fan install issues. Help!
Old Jan 31, 2015 | 11:05 PM
nthaworx's Avatar
Default Silverado Ls1 E-fan install issues. Help!
I installed Ls1 electric fans on my 99 rcsb today, I used the harness from ls1fans.com.. Great kit. It requires tapping into the a/c trigger wire and pinning the #42 pin on the pcm harness, after following the steps to a T, I cranked the truck up and the fans instantly came on, and ran constantly.. So I'm stumped to what the issue could be, any help or ideas would be appreciated!!
Old Jan 31, 2015 | 11:22 PM
2xLS1's Avatar
You don't mention anything about programming your PCM for fan control. What color connector did you wire pin 42.
Old Feb 1, 2015 | 08:30 AM
nthaworx's Avatar
I used the blue pcm connector closest to engine. And pinned #42. And the fans have been turned on. in the pcm via hptuners
Old Feb 1, 2015 | 05:32 PM
SSZ's Avatar
SSZ
Sounds like you may have to make some adjustments to the Fan System settings with your Hp tuners. WOuldnt be surprised if thats where the problem lies.
Old Feb 2, 2015 | 07:20 PM
nthaworx's Avatar
You're probably right. I'll have to get my tuner to check and see if he looked Ovre something
Old Feb 7, 2015 | 06:38 PM
SSZ's Avatar
SSZ
Any updates?
