gto ecm
Old Feb 2, 2015 | 04:00 PM
biorn123's Avatar
Default gto ecm
I am building a 48 chevy truck and have lq9. I am trying to run a 06 gto harness with auto trans because I am running a 90mm dbw throttle body and don't want that adapter. Any how, do I need to run a e40 ecm because I am eliminating all the emissions? Or, is there another ecm I can run?
Old Feb 2, 2015 | 05:23 PM
LSX Power Tuning's Avatar
If your trying to use a GTO harness then yes, E40. If your not set on the GTO harness you can run a LS1 or E38 it will depend on 24x, 58x, what pedel and TB you have.
Old Feb 2, 2015 | 05:53 PM
biorn123's Avatar
i bought a fast 92 intake so to keep my dbw im using a 90mm ls2 throttle body. I have the whole computer and pedal and harness from lq9 just trying to stay as clean as possible under hood. for some reason I thought you could use the 38 if your not going to have ant of the emissions
Old Feb 2, 2015 | 06:00 PM
In order to use E38 you to have a 58x reluctor wheel. Emissions are not a factor either way.
Old Feb 2, 2015 | 06:18 PM
biorn123's Avatar
ah ok thankyou
Old Feb 8, 2015 | 08:30 AM
biorn123's Avatar
does anybody have a e40 ecm for a auto for salei cant post in the wanted adds I also need a gas pedal out of a gto
Old Feb 8, 2015 | 11:22 AM
I have 1 E40 ecm, it's actually out of an auto GTO. I'll sell it either with stock tune or custom tune.
