Basic question on LS1 edit - accessing tables?
Old May 29, 2004 | 09:15 PM
Camaro ChriSS's Avatar
Default Basic question on LS1 edit - accessing tables?
This must be a real dumb sounding question, but I've been playing with Edit today and I cannot figure out how to access any tables.
I can Open a file. Then through the Edit table I can go to Engine Cal, or Trans Cal, etc.. Then I get a window box showing (for Engine Cal) the tabs Fuel, Ignition, etc.., which I can open no prob. If I open Fuel (or any other tab), this is where I have my problem.
I can change any of the displayed values (i.e. in the Power Enrichment frame I can change the Hot Temp value from 142 to 145, etc...), but all the other boxes (RPM, TEMP, Injector Flow rate, etc...) which I assume lead to the tables, I cannot get anything from. This is the same for all edit menus.
What am I doing wrong? How do I get to these tables? I can't find anything on this simple question.
Old May 30, 2004 | 10:35 AM
Someone has to know how this is supposed to be done because everyone can use Edit except for me.
I'm trying to figure out if there is a conflict with my laptop or something.
I try clicking on them, but nothing. Ctrl, Enter, etc... nothing.
I read the PCM fine. I can change some values ok. But I can't call up any tables. Really feeling computer dumb right now...
Old May 30, 2004 | 11:52 AM
JimMueller's Avatar
Are you saying that you click on the buttons and it doesn't do anything, or you click on the buttons and it opens a new window, but doesn't display any data, or? When you click on the 3D button does it 'pop' up and down like it should? Please be a little more specific
Old May 30, 2004 | 01:11 PM
Your first statement is right. I click on the button, it highlights, but nothing comes up. No window at all. No table. I can't imagine that it can be that tough. I assume you just click or double click it...
Old May 30, 2004 | 05:43 PM
I may have solved my problem. Seems like Edit installed improperly on my laptop. It would load, read a pcm, but wouldn't let me access any tables. I have reinstalled it and seems to be better.
