4.8 lsx wiring help needed
Now that i gave you my whole life story lol, here is my first of many questions. i know that essentially a vortec and ls have a lot of interchangeable parts. can i use an ls1 engine harness and ECU on the 4.8. Keep in mind that i am using ls1 injectors and will be running an ls1 MAF sensor? i will be running a manual as well.
Camaro/Firebird harness s pretty nice to work with.
Truck harnesses also work. I find they have a lot more un-needed stuff to remove.
If running a 4L60, you will need an auto trans harness that orig ran a 4L60.
If running a th350/400, a man trans harness works.
You will also need to consider cable TB or DBW. Cable is much simpler.
Prob also easiest if you start with an ECU from a 4.8. Although any will work. A 4.8 operating system can be transferred.
0411 or 4896 pcm are the ones to get. But I've found that the Junkyard will likely have no clue if it came from a V6 or a 6.0.
I bought 5 recently. And got 2 V6, two 5.3 and one 6.0.
Have fun
