What PCM do I have?
Old Apr 12, 2015 | 09:08 PM
03impala9c1's Avatar
Default What PCM do I have?
So I've been trying to figure this out. I'm building a TT LM7 and the PCM I got with the engine and harness I dont believe to be natural to the engine. The PCM anyway...
Its a RED BLUE Warren PCM.
The service number is 09354896. This leads me to believe the PCM to be a 99-00. I know the engine is from an 02 burban.
The hardware number is what I cannot decypher. 09380120. This hasn't popped up on any ls derived charts I've found.
What PCM do I have?! Can I even use it?
Old Apr 12, 2015 | 11:13 PM
mrvedit's Avatar
Moderator
The 896 PCM should work fine with any LS1 engine or even 24x LS2.
However, I would swap to a 411 PCM.
According to this thead, a 896 can be upgraded to a 411:
https://ls1tech.com/forums/pcm-diagn...tune-into.html
Old Apr 13, 2015 | 01:49 AM
RonSSNova's Avatar
My research says the two are essentially identical inside and there is no performance advantage to the 0411.
Once you upgrade to the 3 BAR OS, they are identical.
What is going to be important is the Operating System currently loaded onto your 4896. Not all are upgradeable to 3 BAR. So you need to read it with HPT and see.
You might have to load an OS that is upgradeable.
Ron
