ecm platform change
Old Apr 13, 2015 | 06:36 PM
players 91's Avatar
Default ecm platform change
If someone could help it would be greatly appreciated. I'm looking for info on changing my truck 4896 to an fbody os. Going to be run in 3bar speed density. I've studied cpigs hptuners guide and hp tuners for boost post. I understand how yo install custom os. I've seen ecm info in hpt but I doubt it's as simple as changing platform to fbody. With loading other files from what I think now, you copy and past info from other tunes to yours. I'm probably wrong. Again thanks for any guidance.
Old Apr 14, 2015 | 10:58 AM
RonSSNova's Avatar
You will need to find an Fbody OS in the repository. You will need to license it. Then write entire into your PCM.
Before licensing the Fbody OS, make sure 3 bar is available for it. If it's not grayed out when you look under the OS tab, it's good to go.
This will all cost 4 credits.
Hope this helps
