How do I fix this broken pcm socket?
In another post I asked about fixing it, and somebody said I could swap cases. However, when I took the case apart, the bottom half was empty, and the board, drivers, sockets, etc. are still attached to the top half.
One, it looks like the flange may be part of the board assembly, so I may not be able to swap after all. Because if I pull the pcm, I think the bad flange comes with it. So if I put it in another case, I still have the same problem.
Two, how in the heck do you get the assembly off the top half of the case? I can see 6 teeny little bolts. And some plastic clip looking things. But I haven't figured out how to separate it yet. You can't get at the bolts. And the clips don't seem to release anything.
Help.....
As far as taking it apart... it's just a bunch of hex screws I believe... as I said I haven't taken mine apart in a while.. but when I did it took less than 5 mins... make sure you have all the bolts out and then pry it open a little by hand (you'll hear a noise as you break the vacuum... not to worry the gasket inside is reusable)
Edit: just saw it's a 98 V6 PCM... that i'm not sure about... I know 99+ LS1 PCMs are easy to take apart... but have never looked at a 98 LS1 or V6 PCM up close...
There is some screws holding motherboard to the case.
I have pulled the case end off of a 99 PCM with no problem.
(take a look at the 3rd pic in the original post to see what I'm talking about)
Thanks!
Last edited by John_D.; Jun 4, 2004 at 03:36 PM. Reason: reference to the pics in the first post.
