Engine stutter, low rpm, WOT
Old May 3, 2015 | 11:08 AM
XDR's Avatar
XDR
Default Engine stutter, low rpm, WOT
Trying to diagnose what could be the cause, here is a log file and I experienced this issue around 5:45, 7:45 and 9:00. No other issues noticed throughout the rpm range. Running speed density tune with no DTC associated with this issue.
File Type: hpl
Old May 5, 2015 | 11:50 AM
1 Slow WS6's Avatar
Can't read the log at work but could you be running lean for any reason?
Old May 5, 2015 | 05:35 PM
mrvedit's Avatar
Moderator
I'm a total novice at looking at other people's log files, but I have never seen such crazy swings in Ignition Advance. With a little throttle you have 56* of advance. Then at WOT you sometimes haves 20* of advance, but at other times only 3* of advance.
You did not log anything related to AFR nor Knock Retard.
(I know that what I see you your log file depends upon what I have in my CFG file.)
Any chance you can upload the Tune file too?
Your log .cfg file will help us see the same thing as you.
Perhaps one of the experts here (not me) will be able to help you out.
Old May 7, 2015 | 07:51 AM
1 Slow WS6's Avatar
What are the specs of the motor? Post your tune the timing does look off.
Old May 11, 2015 | 09:51 AM
XDR's Avatar
XDR
Motor is a stock 2001 5.3. Manual tranny with shorty headers. KR was pretty much non-existent. I think the issue may be the fuel pump (Stock Jeep TJ). Here is what I believe the current loaded tune is, I haven't changed it in about a year and still running SD until I get a WB to tune the MAF. As far as AFR, don't have a WB to datalog that. KR can be viewed on histogram #2. The config file I used was the standard one.
Stock Jeep TJ pump is supposedly able to support the motor, have good pressure at rail at idle. Running it returnless with a corvette style regulator/filter setup.
File Type: hpt
