02 sensor transition time malfunction code question
Old Jun 4, 2004 | 06:23 AM
benningtonz28's Avatar
Default 02 sensor transition time malfunction code question
Well, I have been getting this transition time malfunction ses light each time I drive the car. It is always the passenger bank #1 sensor. A while back,I was having problems with that bank. I discovered that my header on that side had melted the sensor wire loom and fried the sensor wire. I spliced in a new longer section of wire and rerouted the o2 sensor wire around the back of the engine away from heat.
Do you have any idea what this transition time code is and how I can fix it?My fuel trim data a on 02 readings from that side seem normal. The o2 sensors are less that a year old.
Old Jun 7, 2004 | 06:34 PM
WILWAXU's Avatar
lets try this in the Computer section.
