flashing ses light no stored code?
Old Jun 1, 2015 | 02:53 PM
wilwhite2kss's Avatar
Default flashing ses light no stored code?
car has been missing between 2500 and 3500 rpm and throwing flashing ses but isn't storing a code for me to read. new plugs wires cam sensor and crank sensor new knock sensors and o2 sensors. car has no cats. all gages are reading good. fuel pressure is also good atleast at idle.what could it be. I was thinking maf but the r really expensive and don't have anybody to let me borrow 1.help?
Old Jun 1, 2015 | 03:35 PM
1FastBrick's Avatar
A flashing SES light is to warn you of a miss fire and that it could damage the Catalytic converters.
You don't have cats so no need to worry about them.
Some generic code readers can not pick up pending codes. Only ones that have set a solid light. If its breaking up under load, it could be a coil pack or an injector. With out a code its hard to know where to look.
You could do a compression check and check your fuel pressure.
Old Dec 12, 2016 | 09:31 PM
rebel98ta's Avatar
did you ever solve your issue? i am having those issues now
