5.3/4l80e PCM
Old Jun 5, 2015 | 02:34 PM
58Rag's Avatar
Default 5.3/4l80e PCM
If I get, lets say, a 2004 5.3 dropout with everything, and a 4l80e 2wd trans, will the 5.3 PCM ( with some tuning ) be able to work the 4l80? From what I've seen, most 5.3's had a 4l60 behind them. I just want to make sure I don't need a different PCM to run a 4l80 behind a 5.3. And I am sorry if this has been covered a million times.
Old Jun 5, 2015 | 06:51 PM
Pacer Racer's Avatar
Yes, it could be made to work since 6.0's came with the same PCM and had 4L80E's behind them
Old Jun 9, 2015 | 05:32 PM
spacemanspif's Avatar
X2. It's what I'm running in my car and been working well for the past 3 years.
Old Jun 9, 2015 | 07:48 PM
rpturbo's Avatar
For it to work properly, you need to do a segment swap on the trans, and make sure you wire in 2 speed sensors for the 80E.
