U0107, red/blue pcm, and dbw question
Should be no power to the TAC module with key off. Otherwise it will try to communicate with the PCM, which has its processor powered down. The TAC module will store a U0107(loss of communication between TAC and PCM) that will already be there as soon as you turn the key on, thereby triggering REP.
Tried something weird and I think I might have found something.
I put a 2x4 under the throttle and it only takes about 1" or less of pedal travel to get to 4900 rpm, but no code no matter what I did. If I remove the 2x4 the pedal can travel much more.
Can allowing the pedal to travel more than intended result in U0107?
If so does this sound like a tuning issue or do I just need a pedal stop? I'd like more than 1" of pedal travel to WOT but making a pedal stop is about as cheap and easy as it gets so I won't complain.
Also, what is redline of a vortec 4800 LR4?
There is always some extra travel in the pedal. You should check where the blade is when you are at 1" of pedal travel. If it is only partially open, you may eventually get to 4800 RPM, but you will have poor pedal response/acceleration.
So, you are saying that U0107 does not set immediately at key-on?
Key-on engine-off, if you move the blade by hand from closed to wide open will any codes set? (Also note how stiff the blade is to move by hand and whether it operates smoothly.)
If no codes set, there could be:
1) a wiring/ground issue: Do you read 0V between the battery negative and Pin 15 (black wire) of the TAC module 16 pin connector key-on and connector plugged in?
2) a bad/incorrect pedal. I would expect some pedal codes though if it was the wrong pedal. 2006 pedal should have the plastic lever arm.
If yes, U0107 sets, it could be:
1) The TB.
2) A bad TAC module is also possible.
If I disconnect and reconnect the battery and floor it I get:
U0107 Lost communication with throttle actuator
P0120 Throttle/pedal position sensor A circuit
P0135 O2 heater bank circuit bank 1 sensor 1
P0220 Throttle/pedal position switch B circuit
P1516 Tac module throttle actuator position performance
P2135 Throttle position sensor 1-2 correlation error
But if I clear those codes they don't return until the next time (except U0107) I disconnect the battery and floor it.
I have the pedal that's completely plastic.
My throttle body clicks at key on and operates smoothly with a bit of resistance.
