larger injector programming problem
I already had my ve table dialed in when it was NA so from what I've read I should have been able to get it close just by putting the correct injector data in. If I put the flow rate vs kpa at 47lb per hour its dead on with my current ve settings. This seems crazy to me? what am I overlooking here please help?
The size of those injectors is not 47.
Are you sure the injector data you had before is correct? VE table should not change if the injector data is correct before and after (in theory).
Are you using a boost referenced fuel rail? If so, take the first number in the IFR table and use it in all cells for flow rate.
