BS3 or Dominator EFI
I put the stock ECU and harness back on for now, the tune should be ok for me to at least fire the motor, it was done with the F1 making 18lbs.
I have very little tuning knowledge but I think I am pushing the limit of the stock ECU. I like the self learn function of the Holley but also hear great things about Big Stuff 3. The tuner that used to tune this car has now moved so either way I am in search of a new tuner in the Connecticut area. Or if I do end up going Holley, do I even need a tuner or is it that self capable?
I have re-tuned a lot of Holley setups that were tuned by the owners and in most cases I didn't make a lot hp but the smoothness and drivability was night and day different once I was done. Holley is the easiest to use IMO out of the aftermarket systems out there.
I think Holley's biggest selling point is the online support via their forums and the updating of their FW.
To make things worse, take a look at the AEM Infinity 8/8h. They have LS harnesses and seem to be very similar in features to the ProEFI.
Most of the traction control systems can get away with placing a sensor close to the back side of the lug nut studs. As long as you have at least 4 stud hubs they will work. It's actually pretty neat.
As an example
I know you said you weren't overly interested in TC but just thought it was interesting.
