need help installing aquamist methanol kit.
Old Jun 13, 2015 | 06:28 AM
stock400whp's Avatar
Default need help installing aquamist methanol kit.
here are the 3 wires that i need to connect.
IGNITION SW. (INJECTOR +)
FUEL INJECTOR (-)
MAP SENSOR (0-5V)
http://www.aquamist.co.uk/HFS6/HFS-6-4w.pdf
heres the 1998 pcm pinout
http://www.ls2.com/boggs/torques/98pinpcm.htm
looks like
Blue (pin 48) is for the map signal
or do i tap into pin 64?
but which pin do i use for the injector + and - ? i only see injectors 1-8 neither say + or -
any inputs would be appreciated thanks
