Help with wide band data logging on EFILive v2 Im almost to the end of my turbo build and its time to get a scan to my tuner to adjust my tune as its running really rich. However I got the wide band installed and got stuck on how to set it up. The wideband has 3 wires. One is a >1 Volt (narrowband) and 1-5v (wideband )and ground. My question is where do I connect these wires. does Ground go to V2 scanner or any ground? Do I use both the 0-1 and 0-5 volt wires or just 1? Here are instructions i got with my glowshift wideband. https://cimg5.ibsrv.net/gimg/ls1tech...cc11fb3141.png |
0-5 and the ground to the flash scan. You wont be using the 1v narrowband wire at all. Then youll need to select the correct PID that goes correlates to your brand of wideband. |
Originally Posted by Rob WS6
(Post 18853807)
Ok I got the PID selected and dont think its reading it. I have the V2 connected and am recording the log via laptop on 7.5 and the Pid is has red X over it after i selected it. Is there something im doing wrong here? Do i have to log with the V2 to get the wideband data maybe? |
© 2024 MH Sub I, LLC dba Internet Brands
