98-99 Wiring Issues
98 Firebird Formula A4
Performed the 99+ PCM upgrade years ago. Engine gave up later, (as 98's do) now I have an 01 LS1/T-56. I used the engine side harness from the 01 SS Camaro roller in the 98 Firebird body. No problem there
I will soon be swapping the whole fuel tank, sending unit, pump and all from the 01 SS into the 98. I have a 00 cluster waiting to be installed for the difference in the fuel pump readings. no problem there
I have contemplated the cluster pinout swap, with a few questions remaining:
I have not seen one whole thread or write up that shows exactly what to do with all the wires, circuit numbers dont interchange (slightly expected). I want the vitals to work, I dont care about ABS, SECURITY, or BRAKE lights etc.
Heres the real question-
I have not seen anywhere that identifies if the Camaro(V8) 99+ body side (that goes to the firewall and feeds the cluster with 2 connectors) is the exact same pinout and color as a Firebird(V8) 99+. Are these 2 in fact the exact same? I have the 01 SS roller that would seem a lot easier to swap that short body harness if they are the same, while ruling out any of the mess of the 98 leftover PCM swap. Any help from the gurus out there? TIA
Yes that is what I was asking. Thanks guys
