Stock lq4 missfire
Old Jul 5, 2015 | 09:26 PM
z22t's Avatar
Default Stock lq4 missfire
Hi
I got a 1988 k1500 with a 99 lq4/4l80 combo.
The engine is stock but a custom intake and no more cat.
The tune is stock too
When i jump on the trottle at about 3500-4000rpm the engine start to knock (even with 94oct) up to the redline.
I did a lot of test and can't figure what the problem is.
-Checked for leak between the maf and tb
-changed the coolant sensor (its worst when the engine is cold)
-when i received
Old Jul 5, 2015 | 09:52 PM
subeone's Avatar
its more than likely a fuel related issue boss.
make sure you have a sumped tank and adequate fuel pressure.
Old Jul 5, 2015 | 09:58 PM
2xLS1's Avatar
Probably the stock 6.0L Power Enrichment delay. Running 14.7:1 A/F at WOT. If you ever run into any GM calibration engineers ask them WTF they were thinking when they programmed them that way.
Old Jul 6, 2015 | 11:09 AM
z22t's Avatar
Fuel pressure is ok
Old Jul 6, 2015 | 11:12 AM
z22t's Avatar
I was trying to make it run good before playing with the tune but i will try it
