Help please with Oxygen Sensor
Old Jul 19, 2015 | 10:25 PM
stebasha's Avatar
Default Help please with Oxygen Sensor
hi all, I bought the engine ls3 crate engine 525 were complete
12581966 Oxygen Sensor (Qty 2 Per Kit)
15156588 Oxygen Sensor Mounting Boss (Qty 2 Per Kit)
I can not understand how to properly install them on the wiring is labeled ODD and Even. I set them so the left header after V band and V band in the right collector. But I have a consumption of 50 liters per 100 kilometers. tell me what am I doing wrong?
Old Jul 20, 2015 | 07:18 AM
joyridin''s Avatar
The odd and even relates to the firing order. Odd is 1,3,5,7, even is 2,4,6,8. The O2 sensors do not matter. You can install them in either side.
I can only assume you drilled a hole int he collector, welded in the O2 bung, and installed the sensors?
Old Jul 20, 2015 | 05:39 PM
stebasha's Avatar
Yes, I drilled a hole, welded in the O2 bung, and screw welded lambda monitoring shows continuously 1.0. Idle speed 1000 RPM
