Delete AIR with HP Tuners?
Old Jun 7, 2004 | 08:49 AM
PewterSS01's Avatar
Default Delete AIR with HP Tuners?
Just got my HP Tuners last week and I took my car back to stock from my Predator tune. I am going to get the AIR system SES light from my headers eventually? Does anyone know how to delete the AIR system in Hp Tuners so I do not get this code? Thank you.
Old Jun 7, 2004 | 11:02 AM
TT_Vert's Avatar
basically you can just shut off any codes associated w/ the system.
Dave
Old Jun 7, 2004 | 11:28 AM
PewterSS01's Avatar
for some reason I cant find how to shut the codes off. anyone know which section it is in? thank you
Old Jun 7, 2004 | 12:27 PM
slow's Avatar
from the editor menu select the edit on the top, engine diagnostics, click the DTC tab, and go down to 410 412 418 and set them all to the way you want them off, either disabled, or just no error reported.
I just turned them off for my friends car with headers and !air.
But i think if you have emmisions with obd-2 your going to want them enabled, with no error reported selected.
Ryan
Old Jun 29, 2004 | 01:15 AM
Rotzy's Avatar
Which option is this? I have emissions testing here.
0 - MIL on first error
1 - MIL on second error
2 - No MIL light
3 - No Error Reported
And what do I set the "SES Enable" to? I'm guessing "no"
Do I do the same for all 5 codes? (410, 412, 418, 1415, 1416)?
Is any of this required if I just increase the "AIR pump disable coolant temp" to it's maximum value (284*F)?
Thanks
