Throttle Cutout
Old Aug 5, 2015 | 01:33 PM
Unachievable's Avatar
Default Throttle Cutout
I just completed a LS swap and I opted to tune with HPTuner. To get the car in the ballpark I also ordered a base tune through PCMofNC. Long story short we took it out to make a few pulls to test the tune and it seems that the throttle completely cuts out mid pull randomly. The setup utilizes a drive by cable system so I know that the throttle blade isn't actually closing however the data recorded suggest that the TPS is at zero percent when this occurs. I have already replaced the TPS and MAF sensor. Has anyone had this issue or can anyone make a suggestion. I have attached data of the problem area in and excel worksheet as well as in the HPTuner form. On the HPTuner data-log the issue occurs from 600 frames to roughly 800 frames.
Side notes
- I am not letting out of the throttle
- VSS is not hooked up
- O2 Sensors are disconnects
File Type: csv
File Type: hpl
File Type: hpt
Old Aug 6, 2015 | 08:41 AM
LSX Power Tuning's Avatar
Without seeing the tune everyone will just be guessing. Was the tune done for no VSS?
Old Aug 6, 2015 | 01:48 PM
No the tune doesn't incorporate a vehicle speed sensor delete it simply isn't hooked up at the moment. I have attached the tune file to this reply and update the post, thanks for you help.
File Type: hpt
Old Aug 10, 2015 | 04:02 PM
thread bump
Old Aug 13, 2015 | 02:45 PM
Brando5641's Avatar
Does it do it all the time or just under hard acceleration? I cant view the log for some reason.
Old Aug 13, 2015 | 05:36 PM
its all the time
Old Aug 13, 2015 | 10:12 PM
Brando5641's Avatar
Loose ground?
Old Aug 15, 2015 | 08:15 AM
I'll look into that thanks for the suggestion
 Michael S. Palmer
