MAP readings in VCM Scanner
Old Aug 10, 2015 | 08:37 PM
Cyrperformance's Avatar
Default MAP readings in VCM Scanner
This is for the Scrapyard S10 in the forced induction section. I have started to get to the tuning on the engine and came across something I have never seen and so far no one can solve. Using HP Tuners VCM Scanner I am starting with the idle tuning and start adjusting for cam and such and notice that the MAP is reading roughly 36-40kpa at 900rpm. KOEO it shows 0kpa, bump the starter and it will read 50-55kpa. So I am not getting the typical 105kpa with KOEO and when we crack the throttle a little it will drop to 20kpa and sometimes less. Running 3bar OS, AC Delco 12623671 sensor from a Chevy Express Duramax engine, 366.7 Linear and 43.81 Offset? The stock sensor has the same effect.
Old Aug 11, 2015 | 08:46 PM
Solved!
Old Aug 12, 2015 | 01:05 AM
joecar's Avatar
Originally Posted by Cyrperformance
Solved!
Details...?
