Tachometer wiring issue (VIDEO)
Old Aug 11, 2015 | 09:03 PM
stukellymotorsports's Avatar
Default Tachometer wiring issue (VIDEO)
Interesting issue with my tachometer.
Anyone have a clue how to fix this?
Check the video.
This is a 2004 truck PCM DBW.
The yellow wire that I have connected to the tach in the video comes directly from pin #10 on the green connector "ENGINE SPEED SIGNAL" .
Did I remove some ground in the deletion process of all the BS ECU pins that I didn't need?
https://www.youtube.com/watch?v=Vqx9...ature=youtu.be
Modify message
This is in an ls1 swapped Rx7 FC
Old Aug 12, 2015 | 05:28 PM
1964SS's Avatar
Have you tried a pullup resistor from tach wire to 12v ignition source? Usually a 1K ohm will do the job.
