PE has me stumped
Old Aug 16, 2015 | 10:13 PM
LETZRIDE's Avatar
Default PE has me stumped
Bit of a weird one here, hoping someone can take a look at my tune and tell me I am over looking something simple and stupid...
WOT tuning in my 2002 ls1 camaro- I am trying to command 13.3 AFR so I have set the EQ ratio for PE to 1.095 across all relevant cells.
I take the car for a spin, go WOT, all is well until I hit about 4800 rpm and then the car changes the command AFR to 12.4 and then 11.70 which is too rich for me.
What am I missing that the command AFR is dropping out on me like that? I zero'd out the table for the operating temps of my car in the Add vs ECT tables...what did I miss?
I'm attaching the tune, my scan and my cfg file. I have a good WOT pull starting at 8:03 in the scan.
2002 camaro tune August.hpt
august17-3PEissue.hpl
Thomastunningconfigurationwideband.cfg
Old Aug 16, 2015 | 10:36 PM
2xLS1's Avatar
Disable COT and see what it does.
Old Aug 16, 2015 | 10:38 PM
LETZRIDE's Avatar
I'll give that a shot- I was thinking about the COT, but I couldn't figure out how it is triggered to know if that was the factor or not...
what about the engine overtemp enrichment? that was the only other thing that had me wondering?
Old Aug 17, 2015 | 12:02 PM
ctd's Avatar
ctd
Your PE delay is @ 5500rpm & OLFA table is adding fuel in the higher MAP & temp cells.
Old Aug 17, 2015 | 07:35 PM
LETZRIDE's Avatar
delay is set to 0 seconds, so that should be a non factor
