Flipping intake, injector wiring
Old Aug 17, 2015 | 06:02 PM
ls1curt's Avatar
Default Flipping intake, injector wiring
I'm flipping my intake and running the tb towards the firewall. Does anyone know if/what has to be done to the injector wiring so that the correct injector fires?
Old Aug 17, 2015 | 06:42 PM
red_00z28's Avatar
I would think the injectors and coils would stay the same. The motor and firing order still have the same orientation. The MAP, IAC, TPS, and IAT sensor wiring would have to be re-routed. And depending on what generation of motor it is the cam position sensor and OPSU might get in the way of the throttle body. Will be cool to see you complete this and make it work. Good luck!!
Old Aug 19, 2015 | 09:51 AM
MontecarloDrag's Avatar
Just keep coils and injector plugs in the same place they are from factory.
I have seen a few flipped truck intakes and it's no big deal.
Old Aug 19, 2015 | 11:26 AM
ls1curt's Avatar
Guess I should rephrase my question. The way my setup is I'm basically flipping the harness over front to back.
Old Aug 19, 2015 | 11:38 AM
LSX Power Tuning's Avatar
Normally just flip the intake and extend the wires that dont reach. The injectors plugs dont move from the factory location.
