hard start
Old Aug 29, 2015 | 03:26 PM
sun20ma's Avatar
Default hard start
Have a brand new LS3 crate engine with current performance wire loom and supposed flashed e38 pcm It will start and run for a few seconds and after 8 to 10 times playing with dbw gas pedal I can get it to idle at 500 rpm with slight miss It is responsive to gas pedal and accelerates okay It only brings up a code of lean bank 1 and 2 and shows also no cold start Does anyone think it is the pcm????? No vacuum leaks and 58psi fuel pressure Any help I really need it It is in a new hotrod with no fans and manual trans
