swaping 99 pcm into 98 corvette
Old Sep 4, 2015 | 08:18 PM
Robert Johnson's Avatar
Default swaping 99 pcm into 98 corvette
Hello,
I am trying to find more info on swapping a 99 pcm into a 98 corvette.
Does anyone have a good source for a repin guide for what wires go where?
Also what do I tell the tuner to flash a 99 corvette tune on the pcm or do I need to have a 98 corvette tune on the pcm?
Old Sep 6, 2015 | 10:25 AM
I'm guessing no one has done this before?
Old Sep 7, 2015 | 03:36 PM
greasess's Avatar
Check this out. Remember, google is your friend. That's how I just found this.
BTW, welcome to LS1 tech
Old Sep 7, 2015 | 10:10 PM
gto65lvr's Avatar
get a baby label maker to keep your sanity it worked very well for me and to label where they started and where they go on each tag. this helps also in case you put one in the wrong place you can track it down easier.
Old Sep 10, 2015 | 04:55 PM
robert19890412's Avatar
What program do I buy to tune it can I use hptuners?
Old Sep 10, 2015 | 09:04 PM
mrvedit's Avatar
Moderator
The repin guide is available here:
https://ls1tech.com/forums/pcm-diagn...cm-99-pcm.html
(I recently cleaned it up and made a few tiny corrections.)
If you first buy a spare set of Red and Blue connectors, you can simply move one wire at a time from the old connector to the new connector and will not have to label anything. Note that the harness will get shorter and have uneven length wires in it; it will be messy.
Old Sep 10, 2015 | 09:57 PM
2xLS1's Avatar
Originally Posted by Robert Johnson
Hello,
How about a reason for wanting to, or thinking you need do it? And if you have to tell the tuner anything about how to make it work you are using the wrong tuner. A competent tuner will know what needs to be done.
Old Sep 10, 2015 | 10:01 PM
gto65lvr's Avatar
Makes a rats nest! 😠
Old Sep 10, 2015 | 10:03 PM
gto65lvr's Avatar
Makes a rats nest and I did mine only because I bricked 2 98 PCM's
Old Sep 10, 2015 | 10:11 PM
2xLS1's Avatar
I was wanting to know the OP's reason. There are really only a few legitimate reasons to do the swap.
Old Sep 10, 2015 | 10:26 PM
mrvedit's Avatar
Moderator
I did it so that I could log more parameters at once in the HPT scanner.
Since I was running OL and MAF-less I also hated dealing with two VE tables.
Old Sep 10, 2015 | 10:53 PM
I don't want to do this but I can't find a new pcm. The one I did find wouldn't accept a corvette tune (according the tuner) and would only accept a camaro tune.
Old Sep 15, 2015 | 10:44 AM
groundczero's Avatar
I am wondering if your how to will work for Corvette isn't the wireing harness different between the vette and the F-body?
