Help tune problem
Thanks a lot for any help
Check for codes and scan data stream to verify sanity of sensors. The PCM will not set codes for sensor readings that are within the realm of normal. A temp sensor that reads 0° at 180° will not set a code, a MAP reading that shows atomspheric pressure with the motor running will not set a code. Etc.
Thanks again
