HP Tuner ??
Old Jun 8, 2004 | 12:37 PM
AGRV8D's Avatar
Default HP Tuner ??
This has probably been beat to death, but here goes.Instead of buying 02 extensions and sims, if i got hp tuner software, will it take care of all the nonsense to where i wouldn't need any of that stuff to make my car run right.
Old Jun 8, 2004 | 01:16 PM
currentman's Avatar
I Have had Hptuner for about a 2 week's now, and I love it. I never used a tuning program before, but HPT works very well and is easy to use.
It took me about 15 minutes to download my stock program, delete the 2 rear o2's, delete egr, and delete air pump, change shift points and upload it back to the car
pesky check engine light is gone, and now I am researching to do do even more tuning, its very easy to use and the help files along with their website has a wealth of information, It's a great tool
Old Jun 8, 2004 | 01:21 PM
slow's Avatar
you won't need !cags, or o2 sims if you have hptuners/edit
Ryan
Old Jun 8, 2004 | 01:39 PM
SidewayzOZ's Avatar
Unless you are wanting to tune your car to run without front o2 sensors you will still need to keep these sensors functioning. You can do away with the rear ones, and take care of their corresponding codes via HP Tuners though(Rather than buying sims). You need the front o2's to make the car run correctly though. You can also make your own o2 extensions for the front if you dont feel like buying any. Search around and Im sure you'll find info on it.
PewterSS01's Avatar
you will still need o2 extensions though to plug in your two 02 sensors on your longtubes.
