EFILive help
Old Jun 8, 2004 | 01:45 PM
n2o-99ta's Avatar
Default EFILive help
I have EFILive and was hoping that maybe I could get some help on wether or not I should get some tuning done? What should I look for? I have a few runs saved but not sure what to do with it?LOL
Old Jun 8, 2004 | 02:40 PM
TimZ28's Avatar
Aside from timing which you can easily see in EFILive you would need to check your A/F ratio with a wideband O2 sensor. You cannot simply look at scantool readings to determine whether or not your A/F ratio is correct.
Tim
Old Jun 8, 2004 | 03:47 PM
n2o-99ta's Avatar
What does this wideband O2 sensor do? And where can I get one.
Old Jun 29, 2004 | 02:29 PM
35thss2's Avatar
to the top
also interested in knowing where to find the O2 sensor
