98 starter relay - any idea how it's grounded? Magnus (and I) finished up the FAST standalone in my car last weekend, but had to rig up a ground solution for the starter relay. Any idea how it's routed stock? |
Give me a hint on where to look for it and I'll go check...... |
According to my Helms ('98 2nd Edition Service Manual) the starter relay grounds through the BCM. Yel/blk wire out of the relay all the way to the BCM. |
After we yank'd the PCM and harness the BCM wouldn't ground the starter relay (found in the driver side fuse center). It took a good 45 minutes of fierce volt meter and yelling to figure out what the problem is. ps. Car fired up today. :) .... and it didn't blow up either!!!! |
| All times are GMT -5. The time now is 06:31 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
