E38 PCM pinout for Fan
Old Sep 22, 2015 | 12:14 PM
tdishon's Avatar
Default E38 PCM pinout for Fan
Does anyone have a diagram of where the pinout for the cooling fan relay is located?
I think it is Pin 17, but not sure which of the two harnesses it is and where it is located. Also is the relay control pinout negative?
Thanks for any help
Old Sep 23, 2015 | 02:38 AM
Bubba68ss's Avatar
pin 17 for high speed and pin 58 for low speed
Old Sep 23, 2015 | 11:43 AM
tdishon's Avatar
Ok, Pin 17 it is since I have a single fan on this car(62 corvette).
Is it a negative output from pin 17 for the relay or positive?
Old Sep 24, 2015 | 08:06 PM
Grip's Avatar
Check www.lt1swap.com. He has the pin outs. The signal is negative. He has a diagram for wiring the fan relay too.
Old Sep 25, 2015 | 11:12 AM
tdishon's Avatar
I think since I only have one fan that I should be connecting to pin 58.
Old Oct 15, 2015 | 09:18 PM
Grip's Avatar
Have you got it up and running? I have read that the tables for controlling fan set points can be confusing with the E38.
Old Oct 16, 2015 | 07:19 PM
Project GatTagO's Avatar
You can also use PWM fan control with the E38 and a C6 fan controller. I would do this for sure!
Tons of info here:
http://www.lateral-g.net/forums/showthread.php4?t=40215
Andrew
