Another 80e unlocking at light throttle thread..
Old Oct 2, 2015 | 04:31 PM
MikeD.'s Avatar
Default Another 80e unlocking at light throttle thread..
Finished my 80e swap in my sierra, and have a question on my converter unlocking at light throttle. So I have done the research and know that I need to adjust my release speeds, but the problem is when I set them to 256, 256, and 0'ing out the last 4, it makes it NOT lock up at all after that, at anyspeed/throttle? Everything else works great after using the bluecat tables (which are absolutely amazing). Putting it back to stock specs in these tables allows it too lock up like it should, but then it unlocks when I let off for a second. Any ideas?
Old Oct 2, 2015 | 08:06 PM
Russ K's Avatar
Leave the Low & High speed VSS fields stock, and zero the TPS% fields.
Russ Kemp
Old Oct 3, 2015 | 10:11 AM
MikeD.'s Avatar
Alright I will just set those to 0. Just for reference, I saw a few guys setting the top boxes too 256, whats the point of that?
