KO sensor question
The motor runs like glass. The bent valve and broken guide repair was successful. The valve got bent after the rocker arm pounded its way through the aftermarket Ti retainer. This happened slowly over several thousand miles, until it finally broke. Hence, the sensors did not register a code. But, they do now since the repair.
I am thinking of disconnecting the KOs. Will this cause the computer to retard or tamper with the motors performance. Or should I continue with relearning until the computer relearns the engine sounds. The motor runs like silk and I am not going to start removing parts to repair this. Any thoughts you may have on this issue is appreciated. Red.
Having said that, I have read posts on how to change them correctly. I am operating under the assumption that maybe, just maybe, the knock sensors maybe on to a new noise or harmonic after the valve change. I am looking for advise as to how have the KSs relearn the motor's harmonics after changing a bent valve or other major parts. If someone is familiar with this issue, please instruct.
If the KSs prove to be at fault, then I will replace them as instructed. In any event, thanks for your time.
