Holley efi "quick keys"??
What I'd like to know is if there's a list of quick keys, or hot keys somewhere. For example on my aem system I can highlight a section of the map and hit the letter p and a box opens up so I can do a percentage change to those cells. Or when working on a X and y axis table like coolest temp enrichment once I set the high value and low value I can hit the H key and it will smooth all the values in between.
More importantly I need to know how to add or take away fuel from the injector pulse. With aem after you highlight the cells you can simply hit + or - to add or take away from the pulse width.
Any help would be greatly appreciated!
anytime you click on/Highlight cell values
CTRL+ Up/Down Arrows = Change by +/-1%
CTRL+ Left/Right Arrows = Change by +/-5%
CTRL+X will Zero out the cell/highlighted area
if you click inside the visual chart area of tables , whatever point you highlight, you can use the up and down/left and right arrows to move/adjust
on 3d charts the CTRL+Arrow keys works the same as when looking at the cell values
ALT+[Key]
A = Acceleration Enrichment
B = Boost Setup
C = Trans Shift Parameters
D = Drive By Wire Settings
E = Engine Parameters
F = Base Fuel
G =
H =
I = Idle Speed
J =
K =
L = Fuel Learn Table
M =
N = Nitrous Parameters
O =
P =
Q =
R =
S = Base Spark table
T = Ignition Parameters / Rev Limiter settings
X = Cranking Fuel Table
Y =
Z = Target Air Fuel Table
