timing and fuel
Old Nov 6, 2015 | 08:45 PM
Seeker1056's Avatar
Default timing and fuel
I have read hundreds of threads through search and nothing relevant to what I seek
I am looking to boost 8-15 lbs - on my twin turbo 6.0 4l80e build
I am brand new to gassers and turbos but well versed in diesel boost to 85 psi
anyway - I can not seem to find anywhere that speaks to basic timing and fuel needs - I am setting up with 80# injectors to start
what I am looking for is timing values ie how many degrees to start, and how much timing under boost or is it the old rule of thumb of removing 1 degree timing for every lb of boost so like start with 32 degrees and look for 12 degrees or so at full boost?/
what fueling am I looking for under full boost - 11:1 12:1 ?
I have a friend with EFI live but again , like me he is a diesel guy
does anyone have a decent EFI LIVE tune they could sell me to get on board fully and that we could just tweak from there
I will read and study my heart out if someone could point links that I could not find
any help would be appreciated
thanks
Ken
Old Nov 9, 2015 | 12:33 AM
joecar's Avatar
Hi Ken,
The rule of thumb gives you a base tune...
but then, you will still need to get timing determined on the dyno (in addition to tuning for air/fuel).
Old Nov 10, 2015 | 10:31 AM
watman02's Avatar
Fueling 11.5afr with pump gas.
As for timing 14* is a good start if you have 93oct.
And go from there as long as you don't have knock.
Old Nov 10, 2015 | 06:22 PM
Seeker1056's Avatar
thanks watman02
