Adding traction control to E67
Old Nov 10, 2015 | 11:57 AM
tdishon's Avatar
Default Adding traction control to E67
I have a crate LSA in a build with the GM performance parts wiring harness which has the E67 PCM. Is there a kit or a way of adding traction control?
Old Nov 10, 2015 | 10:06 PM
01WS6/tamu's Avatar
No traction control is a function of several different systems working together in conjunction with each other over the data bus. And the calibration in the GMPP pcm is not setup to even look for the interaction from other modules. That's whole reason GMPP designed the system the way they did it's a educated carburetor designed to suck bang blow via pcm control
Old Nov 20, 2015 | 09:27 AM
Old Geezer's Avatar
" That's whole reason GMPP designed the system the way they did it's a educated carburetor designed to suck bang blow via pcm control"
Yep. Exactly what we're finding on a swap brought in for a wiring job.....
Old Jan 13, 2016 | 12:41 PM
tdishon's Avatar
Well, that just takes the wind out of those sails. lol
