1992 GMC Sierra Ignition Switch Problem
This is not a tuning related questions but, I didnt know where to put this.
I have a 1992 GMC Sierra and this morning I went to start the truck and the key went to the start position where all the lights come on but, the switch would not turn into the run position to activate the starter. It was locked. I put the truck in neutral and let it roll a little then put it back into park and tried again, no luck. I have never heard or seen this before.
Can someone point me in the right direction for fixing this? Thanks
Ignition switches never give trouble on those trucks.
Probably about 75.00-100.00 worth of parts from a dealer. You can get the rack for cheaper at parts house but they are cheap chinese crap and will fail in 6-8 months because it is made out of potmetal and you will be back at square one.
Thanks for the information and I ment the key lock cylinder not the ignition switch. Thanks
