Grouded
Old Nov 23, 2015 | 09:17 AM
SpeedFreak7's Avatar
Default Grouded
Alright guys. I've had two 1998 trans am ws6s, the first one ended up being my diner car. But before that, while she was running strong and hard, the gas gauge wasn't working. It would stay pinned at full. And my current car, it's reading full too. I swapped out both pump assemblies in both cars, both two brand new ratronix assemblies. And still reading full! So my guess is something is grounded out in mid way or towards the gauge cluster. Cause the needle moves slightly enough to tell there's juice and not a stuck needle but dang I'd like to know if I'm full or about to putput home. Anyone out there know anything or HAD similar isues before I take the car apart again. Thanks
Old Nov 23, 2015 | 09:31 AM
Won-Ton's Avatar
Is it a 0-90 ohm unit? If you have a DMM, you can ohm it at the meter and if possible move the float up and down to see if the ohm reading changes.
