thanks for the replies. Here is what I am dealing with now.. behind the mess of speghetti wires lies relays attached to a 6 block fuse panel.. I will be pulling each constant power (fused connections) to this block. Another 6 block fuse panel will be housing fused switched power. I also put in 3 main power distribution blocks for main power and ground and switched but I am rethinking the switched non fused power distribution block. My keyless ignition is asking me for a acc (+ switched ignition) and also ON1 (+ Constant) ON2 (+ Constant) Also a SWITCHED ON ( + Switched ignition)
I am assuming that I can NOT pull power from the PCM from a tiny little 18 gauge wire. to power my entire Switched power fuse block?
I am just trying to get on the correct path to execution of this wiring. This wiring and lying on my back is killing me.
