MS3 gold box pnp
Old Dec 7, 2015 | 02:37 AM
360demonRT's Avatar
Default MS3 gold box pnp
have a couple questions about it. I'll be purchasing an efi setup in a couple months and have done some research, but am left wondering on a few points.
Initially the car will be running a nitrous l76 setup, and while I see a whole lot of turbo users with the MS3 setups, I don't see (or haven't been able to find) anything on nitrous usage. I see it has two nitrous inputs and one output, what kind of nitrous control does it have? I want to run a dry shot (200ish) and progressive would be great like I was available with the Holley hp setup I had.
Next with the pnp setup, it has two o2 inputs. I assume it uses a stock factory o2, similar to the rest of the factory sensors and that it doesn't require any kind of drivers?
Lastly, I see it says it has ((3 additional general purpose inputs (on/off or frequency)
1 additional analog input)).
That doesn't seem like many extra inputs? is that it?
Thanks for the help!
Old Dec 7, 2015 | 04:14 AM
360demonRT's Avatar
I believe I found that it does have a progressive control for the nitrous, and I will have to have controllers for a pair of wbo2's.
Still looking for total input and output availability. I want to use the traction control so that's 2 vss sensors already.
