O2 issue
Old Jan 9, 2016 | 11:41 AM
BOTTLE ROCKET's Avatar
Default O2 issue
Does anyone know of a reason that my O2 sensors are not "cycling" at idle on my SD tune>> :*****:
I have a 98 that has a 02 PCM. at idle (up to around 1400 rpm) the O2s stay in the 900s and the AFR is in the 12s. If I rev it up to around 1400 in gear, the O2s cycle perfectly and the AFR is close (VE needs tweaking)
I purchased new O2s and it didn't help, so the original ones are actually in it right now
I have been fighting this issue for around a month, :crazy: but a crazy work schedule, the holidays and consistent rain every weekend has hampered any testing. I'm ready to get this thing back on the road:yesnod:
Old Jan 9, 2016 | 12:21 PM
joecar's Avatar
Default O2 issue
If you're truly in CL you should be seeing negative LTFT's...
Post your tune file.
Old Jan 9, 2016 | 01:43 PM
Thanks JC
Here is the latest tune. I have it set to go into CL at 90*
File Type: hpt
Old Jan 9, 2016 | 04:50 PM
2xLS1's Avatar
Is it setting O2 codes? Log Fuel System Status.
Old Jan 9, 2016 | 05:36 PM
only codes are 102, 103 from having the MAF out
(I have 101,102,103, 106, "unchecked" and no mil light)
