How much timing to pull for spray........
Old Jun 12, 2004 | 05:27 PM
Quickin's Avatar
Default How much timing to pull for spray........
If I'm going to drive around N/A all the time, how much timing is pulled for a 150 shot.
I mean how do you know how many degrees to pull so you get max power when on the spray?
How much N/A RWHP will I lose if my 436 is set up with less timing on motor?
Old Jun 12, 2004 | 11:16 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Some folks reccomend pulling a couple degrees for every 100 hp of nitrous.
Old Jun 13, 2004 | 09:09 AM
n2opwr's Avatar
2 degrees for every 50 hp
BTL FED's Avatar
The "General" rule is 2 degree's for every 50 horse, but most people dont change anything for 100-150 shots
Old Jun 13, 2004 | 12:55 PM
Quickin's Avatar
Well than, if I want to spray a progressive 300 shot I would have to pull 12 degrees??
How much RWHP would that take away from say a 500 RWHP N/A engine?
